mportpwr
- November 5, 2006
- Pataskala, Ohio
- '07 Sport Trac Limted V8
Help me, please!
Yesterday I ran Seafoam through my '99 SOHC 4.0. I used the IAC method, and slowly funneled the entire can into the running engine. There were some hesitations, but never a stall. Once the whole can was in I shut it down and let it sit for about 15 minutes. It did begin with the white/blue smoke before the entire can was in.
Afterwards, start 'er up. Lots of smoke and a bouncy idle. Drove down to an empty street, and throttled up to 2k and held it there until the smoke cleared. Temp gauge never moved above halfway. CEL light came on, but no change in running while at 2k. Went home after the smoke stopped, shut it down. Later that night, started it and it bounced around, shaking the whole truck. CEL still on. It calmed down after a minute, so this morning I drove to work. 10 miles there with no problem. After work, I head to Advance Auto to read and clear the code. They tell me it’s a misfire on #5, and will not clear the code incase I need dealer diagnostic. So I come home, and it starts getting worse. CEL starts flashing, then back to solid, then flashing, and so on.
I check the plug for #5, and it looks good. Getting a huge spark. Check to make sure the distributor is sparking the rest, and all are throwing. Engine still runs like crap at idle, and the CEL is still on. I cleaned the IAC and the hoses and fittings, but no improvement.
Any help or suggestions are much appreciated.
-Kevin
-Kevin
