davidhicks16
- July 31, 2009
- oreana il
- 94 xlt
I finally replaced my old broke down front seats in my 94 with a set of second gen seats!!! If you want to do this your self its easy as pie.
First off the seats i picked up all full electric my stockers were not. When you pull the seats from the doner truck leave the all the wires plugged in just cut them with about 8 inches of extra wire.
Second pull the driver seat from your first gen(13mm) Now you take a t50 torxbit and remove your bottom seat belt latch.
Now on the new seat remove the bottom seat belt latch and replace with your stock one (the plug is the same)
Now you are ready th bolt the new seat in, and it bolts directly in to your stock holes.
Now if your truck like mine had manual seat you get to do some wiring. There should be 2 plugs on the back One is yellow one is black remove and disregard the yellow plug(its a dummy plug ford was required to put in) At this point you should be left with just one black plug, You will have a black wire and a gray and black striped wire(The solid black is a ground and the striped wire is your hot wire) You can ground the seat to a seat bolt. and run a wire to you fuse block and splice it to the seats hot wire.
So with an hour or 2 of work you can put full power seats from a second gen in you first gen....
