backporch
- April 22, 2018
- Freehold NJ
- 2000 Explorer XLS
Yes.. E12 was correct thanks. Just for the record, the lower engine mounting bolt did not easily move when tapped with a hammer. I will probably use a combination of turn and tap to work it loose. I personally think it is crazy that a bolt can become "pressed" into the transmission "though hole" with whatever was on the bolt ( corrosion, dirt, etc.)
Next I face seriously deteriorated exhaust manifold nuts/studs. That should be fun replacing them.
