cereal killer
- October 17, 2012
- Calgary, AB
Hi everyone. I was offered an '02 Explorer Sport Trac as a trade for my BMW 535i I have for sale and I have a few questions about this truck. My BMW is older and worth ~$2500, the Sport Trac would sell for ~$3500 here in Alberta -so it seems like a great deal right?
However, the owner says he recently experienced a shift flare. He says he got the transmission flushed and it has gone away. After reading through these forums I have the impression that this is a relatively common issue with the transmissions on these trucks and can be caused by problems with the valve body or servo bore wear - both of which probably won't be solved by a flush.
I think I can handle a VB swap or the o-ring fix for the servo (http://www.fordservoboretransmissionfixsolution.com/), but is there a good way to tell which one of these is the problem?
Should I walk away from this trade? I need a truck, but if I have to put a new transmission into it... it won't be worthwhile. Is this an issue that most people solve without dropping the transmission?
Thanks for your help!
