Shift Motor/Manual Transfer Case Conversion? | Ford Explorer Forums
theodosia
Bloomfield New Mexico
1994 XL
Hello I'm a new member I have a 1994 explorer XL. I would like to know of there is a conversion of some kind that would allow be to put a shift lever in place of the solenoid to shift the transfer case in and out of four wheel drive. It already has locking hubs. Its a very basic model with no power any thing only option it has is cruise control. Hand crank windows and all.
joel theodosia
interesting. im gonna keep checking on this.
welcome to the forum
If you do a search you can find a picture of a setup like this. It's not a lever though, it's a knob. It uses a flex shaft, attached to the shaft in the x-fer case. Turn the knob to select where it goes. It's a way around the electric shift but I don't like it all that much. If you're having problems with your electric shift look up how to clean the shift motor, it's a very common issue and can be solved very easily.
