Evicerate
- November 16, 2003
- KY
- 1994 XLT
Well, happy holidays to everyone. Mine isn't so happy as it would seem that my slave cylinder has gone out again and I need to know what to get replaced, etc.
Currently I have a 1994 XLT 4x4 with approx. 117K miles on it. At about 90K I had the clutch and all of the other goodies like the master and slave cylinders, bearings, pressure plate, etc replaced all at once.
Then, a year later, I had to have the slave cylinder replaced again, as it went out. Fortunnately it was under warranty and its been fine until now. :fire: This time it isn't a slow leak where I can top off the resevoir and drive to the shop. I topped off the resevoir and the fluid is gone again in a matter of seconds. I have no pressure in my clutch pedal, so I'm assuming its the slave cylinder again. Also, I can't see a fluid leak, as there's 10 inches of snow beneath the Ex and the fluis is clear
So, here are a few questions I have for you guys:
Can I be doing something wrong to kill my slave cylinders so quickly?
Is this just a case of a cheap part that's crapped out? (previous warranty was only for a year, so the current slave cylinder is NOT under warranty)
Will I be ok to get the slave cylionder alone replaced, since the other parts have under 30K miles on them? If not, what else should be done while the tranny's off?
Thanks a bunch to anyone who has some insight.
