Bored_2wd
- May 5, 2000
- Westmont, Illinois
- '93 Ranger
Brief history of prjct starts with bad 2nd gear syncro in trans. Bought replacement junk yard trans, pulled the old, installed the replacement. Bad bad error: I SHOULD have switched the two slave cylinders because I know my existing one is good. Don't know the condition of the junk yard one. But I forgot to switch them. So now I'm stuck with the unknown one unless I end up dropping the trans again. Since then I've spent hours bleeding the clutch to no avail. Just tonight I finally got my wife out there to help. I'd open the bleeder, she'd slowly depress the pedal, and I'd close it at the bottom. After doing this about 20 times, I saw movement of the slave through the little porthole in the bellhousing! But I'm guessing not enough movement. So we kept at it. Finally gave up a few moments ago, both exhausted from the day. Truck still 'TINK's when attempting to start, meaning that that slave cylinder still isn't moving enough. I'm just guessing that it needs to move a little further. Now finally I'm getting some good fluid out of the line on the bleeding - tomorrow I'll just do this again, hey maybe it will work afterall. Fluid level didn't go down at all overnight, and their doesn't seem to be any sign of a leak that I can see. ARgh.
--Bob
--Bob
