Slipping transmission | Ford Explorer Forums
a320jockey
Quito
2002 XLT
Hello all,
I have been wandering around this forum to read about what may be my 2002 XLT Explorer 4.0 automatic 4 speed and O/D transmission problem. It has 106,000 Km, which is around 66,000 miles. A month ago the transmission started to slip when driving uphill, mainly when shifting from 2nd to 3rd gear. It also takes longer than expected to shift from 2nd to 3rd gear and bumps sometimes when shifting, so I usually step back the throttle pedal to make it shift. It also takes a second to engage the reverse gear and has a slight bump when engaging, specially on a cold start in the morning. After I took the car to the shop they found that the transmission fluid was low and "not in a good condition", so they changed the fluid and filled it to the appropriate level. While the problem was solved for the first week, it showed again. The guys at the shop checked it again and adjusted the transmission bands, however it is still slipping. They say that fluid pressure is normal and that there have been no fluid leaks. I read in the forum some comments about a bad solenoid or a worn transmission filter (?). I would like to have some help before considering a transmission rebuild, which was mentioned by the local Ford dealer before doing running any diagnostics on the car.
Many thanks in advance for your help.
Carlos A. Cordova
QUITO - ECUADOR
Welcome to this forum! I've moved your post into its own thread. The dealer always wants to sell you a rebuilt transmission. It's possible that the fluid isn't at the correct level since you said that it was fine for a while. Check this link for more information: http://www.explorerforum.com/forums/showthread.php?t=118654
