Slow gas fill then sucking sound | Ford Explorer Forums
blueoval9erlifer
OAK HILL, KANSAS
04 explorer XLT
Hi all, Ive done my research and im pretty sure the problem is the vapor canister purge valve, but first im going to check the vapor/vacuum hose.
My problem has been getting worse and the only way to fill my tank is i buy 10 gallons of gas and then fill my tank with gas cans, when I'm done i getting a sucking sound from the fill spout for about 15 to 20 seconds I think it's the tank equalizing the air out. Was wondering if anyone else has ever noticed this when they had problems filling their tank? If so what did you do to fix?
Thanks
Took the hose loose and blew it out from the bottom no difference, guess its time to get a new vapor valve.
I have seen several threads about this before. I have checked my shop manuals and can't find anything on this concern. I guess I don't know where to look. :dunno:
Here are some threads that might help out:
http://www.explorerforum.com/forums/showthread.php?t=335620
http://www.explorerforum.com/forums/showthread.php?t=214304
http://www.explorerforum.com/forums/showthread.php?t=298897
http://www.explorerforum.com/forums/showthread.php?t=296417
http://www.explorerforum.com/forums/showthread.php?t=283856
http://www.explorerforum.com/forums/showthread.php?t=283446
http://www.explorerforum.com/forums/showthread.php?t=251086
http://www.explorerforum.com/forums/showthread.php?t=228727
Like I said, I can't find anything in my manuals about this, but if you need anything like removal procedures, etc. Let me know. :D
Thanks for the links Rondo always appreciated. I had read part of them and was wondering if anyone else had the same noises i had. Got to get it fixed before my wife fixes me!!!! She is not to happy that it takes forever to fill up when its cold out
You're welcome. ;):thumbsup:
Good luck getting it sorted! :biggthump
