Smooth or ribbed belt tensioner? | Ford Explorer Forums
davidk
Sacramento, California
'93 Limited
My belt tensioner spring is wearing out - time for a new assembly. My OEM pulley is smooth. The ones I see online have ribbed pulleys. Does it make any difference what I get? Thanks!
David
Tensioner pulley is ribbed on my 08. Check Rockauto.com as a great reference.
David
I'm assuming you are asking for a 1993 Explorer.... the issue is... 1993 is when they changed from a top mounted tensioner (by the thermostat) to a lower mounted tensioners (under the alternator).
Soo... It sounds like you have a top mounted one since it's smooth... and smooth means it runs on the back on the belt... The ribbed runs on the inside of the belt and that tensioner is under the alternator...
Here's some from amazon that'll for for the smooth pulley, top mounted tensioner
Gates 38134 - $48
Hayden 5866 - $9 (yes, < $9 only 1 left)..
~Mark
Interesting... My '92 XLT and '94 Limited have smooth tensioners, and my '94 has the extra odometer digit so it's one of the later '94's. (I also have a '94 'parts car' without the extra odometer digit.)
Gates 38134 - $48
~Mark
THANKS!! And yes, it is for my high mileage 5 speed 93 (oops for not mentioning that).
