angstrom08
- September 24, 2014
- Mid Michigan
- 2001 Explorer
Describing a 2001 rwd explorer with the regular differential.
So, I made the mistake of asking a friend instead of checking the manual and was told 85 ft lbs for the differential cover bolts. And... I snapped the bolt. I checked the ford workshop manual and it's supposed to be 33 ft lbs. I was able to install and properly tighten the remaining bolts. This bolt is at roughly the 10 o'clock position. Image attached.
Given that the broken bolt is at or above the fill level, my amateur opinion is that its necessary unless I attempt to drive through a river. Also, since I'm very inexperienced, if it needs repair I think taking it to a mechanic or dealership - to prevent making the situation worse.
Basically, the question is, should I get this fixed ASAP, within the next month, or not really necessary?
Thank you for your patience.
