awdrocks
- April 30, 2005
- Cancun
- 2002 Eddie B.
Well I finally got my Snow meth/water kit.
I should start the install this weekend, and tune for it during the week.
On the left is the Safeinjection that will reduce boost if the system fails or when the juice reaches a low level in the reservoir. Also has a cool little LED that mounts inside the car so you know if something is wrong.
And on the right is the Boost Cooler Stage-2 MAF kit with the upgraded 7-qt Reservoir, kit comes with a 2-qt.
I found a nice spot to locate the 7-qt reservoir by the top left firewall.
I will start the testing with the 375 nozzle and have the spray turn on at 2.9 MAF volts and 100% full spray at 5v.
I also have on the way 2 cases of Boost Juice from Snow Performance that contains water meth.
My current inlet temps reach as high as 180 degrees on HOT days and average about 170. At nights I average about 150 degrees. If the system does what's promised I should hopefully see about a 30% drop in inlet temps. I'm the ideal candidate with a roots blower.
If I can see 120/105degrees day/night inlet temps that will be phenomenal. My night driving compared to my day driving is a dramatic difference... the extra timing from the lower inlet temps makes a huge difference...
That's with the water.
Then the meth is said to raise your octane level from 92 to about 116.
So in the end it should run like I have an aggressive tune with race fuel.... I can only hope for.
