so i burned through my manual clutch line! | Ford Explorer Forums
93explorer4life
Bloomfield, Indiana
no curent
i just finished putting on my exhaust, and aparently the line was against the exhaust, and it burned through, so i need a new line...i guess unless some one can let me know how to fix it, im not even sure how to take the line out! so please help!!!!!! its my d.d. and i have nothing!!! so i need some help BAD!!
tranny guru should be able to help...sounds like this should go in the whoops section, lol...
The line has a quick disconnect fitting right outside the transmission. Search for how to do it if you don't know. At the other end, the line is held onto the clutch master cyl by a pin that slides out. I used the point of a nail to push it.
thanks,
c'mon, c'mon.. do I see four threads about this. No whammies no whammies big money big money.
my bad, its been a long week, with the tranny swap, and all the problems, and now this!
sooo. i figured out that to romeove the line from the slave, u push that pin out!
now im stumped on the trannys line, how is it taht u disconect it, and where can i find a new line! FOR CHEEP!!!!!!!!!!!
