torqlox
- April 6, 2007
- Cape Coral, FL
- 99' Explorer XLS
For most 2nd gen Explorers with the "third shock" (Axle dampener) and 5.0L machines that have factory "track bars" (anti-windup bars), You don't have to lose them after SOA! After a little research and digging, I found a few ideas that make these parts work!
As for the Ford Factory Axle dampener, it's too short and does not reach both the frame and axle eyelet mounts. It is merely a 14" at full extension, and allows 4" of travel. After some trial and error I found that the 89-93 5.0L Mustang axle dampener is the perfect length at 18.73" and has 5.75" of travel! It also looks way cooler and only $22.00 free shipping on Amazon . The part number and model you are looking for is: "Monroe 32242 Monro-Matic Plus Axle Shaft Damper".
As for the factory traction bars, all you have to do is find some 1" pipe with an I.D. of 3/4", and extend them by exactly 1 3/8". This is the exact measurement that allows the bars enough slack for when the suspension droops and compresses. you just need a good bead weld around each sleeve where it touches the rod. I personally had a 6" steel rod bored with an internal thickness of 3/4" on each end to a depth that allowed a 1 3/8" section of solid metal in the middle for more rigidity. See pics below!
Missing Axle Dampener after stock one was too short to re-install.
New Dampener
P/N
Size Comparison with Stock
This blue dampener must have sat around for nearly 10-15 years. I guess Mustang owners never replaced them much.
Axle Mount
Frame Mount
Side View
Modded Track bars after refinish and paint
I rode around with just the track bars for about a week before I found this dampener. Acceleration and throttle response had already improved a great bunch, but after installing the dampener, it's night and day. I can feel so much more energy being applied to the rear wheels versus the vehicle body, even with my heavy 285/70/17 BFG Muds which need replacement. Hope you guys benefited from this. I always believed there is a reason the engineers put these items in place, so there is no reason to lose them when performing SOA. Talk to ya later. -JT
New Dampener
P/N
Axle Mount
Frame Mount
Side View
