soa help | Ford Explorer Forums
soa help
rawlins32
covington georgia
1998 explorer sport
i recently did a soa conversion on my 1998 explorer sport..and i took the bracket that was under the axle off and mpoutned it on top without welding it..should i weld it? and i only did a torsion twist 2 inches on front..what can i do the even it out?..thanks
You can buy a 4" lift kit for the front end in addition to the Torsion twist you did. SOA gives you roughly 5" to 6" inches of lift in the rear.
do i need to weld the plate that the leaf springs rest on on top of the axle
I would.
The perches are supposed to be welded to the tube once you set the pinion angle.
where can i find a 4 inch front end lift
How did you remove the spring perches?
I'm curious because typically, the spring perches are eaten away by a grinding wheel or a reciprocating saw.
my uncles body shop did it..i dont know how they did it
Oh, well then they probably replaced it with another spring perch - cheapest and easiest solution.
As for the front-end lift, please Search - there are many threads on this topic.
yea i just looked and the old perce is still there...can anyone tell me where to get a 4 inch lift for my front end
