Extremerc12
- September 14, 2011
- 2014 Ford Explorer Base
HEllo all,
Have a 98 Explorer 6 cylinder 4L SOHC that has soft front and rear timing chain tensioners. I can put the tensioners in oil and manually pump them rock hard again. Is this an indication of one, bad tensioners or two, an oil pump issue not keeping the tensioners pumped with oil. The reasoning we removed the tensioners was due to a timing chain rattle. We removed and replaced the rear tensioner because of the soft feeling and we believed the tensioner was at fault. The issue still persisted. We removed the front tensioner and found it to was soft with no tension.
Any help would be appreciated.
Thanks
Chris
Thanks
Chris
