bpopp
- February 21, 2007
- 99 Explorer 4.0 SOHC
I had a leaky radiator that I ignored for too long. It eventually led to overheating while my son was driving and then I eventually noticed white smoke in my exhaust. This got worse and eventually I started having misfires. When I pulled the engines/heads, I found coolant in cylinder 1:
I like working on cars, but as you'll see, I'm still a novice. I originally assumed head gasket failure and/or warped heads and I was hoping to not rebuild the block (around 180k miles). It appeared to me that the gasket failed between the cylinders, but I honestly didn't see any obvious damage to the head gasket.
The heads are at the engine shop being cleaned, surfaced, and reworked. While I waited, I started cleaning up the block. There's some pitting around the water jackets, but it's flat and I don't believe the block surface is too bad. Unfortunately in cylinder 1 there was some staining and I started to worry that it was a crack and in a moment of weakness and panic, I scrubbed it gently with scotchbrite. It cleaned up, but I noticed that when I turn the crank, there's a straight bead of oil left on the cylinder wall. It feels perfectly smooth and I can't feel anything with a fingernail. Could this be a crack? As you can see, I unfortunately scratched up the wall of the cylinder with the scotchbrite.
Based on this cylinder, does this block need to be rebuilt? I'm not looking for this rebuild to last forever, but I dumped $500 into an OEM timing kit and another $500 for the heads and gaskets so I obviously don't want to throw a rod after a week. I'd be very happy to get another 50k miles out of it. Thanks for any advice.
