- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
The noise at any time or temperature means that one or more of the valvetrain chains is loose. The answer is to fix the problem, not to do something with oil or additives or the starter.
The problem will not get better. The problem is either a weak spring in a tensioner, or a disintegrating timing chain cassette(plastic). If you wait, the engine will die, literally, with no repair possible after it happens. Fix it now, not later.
