2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
knock sensor retard w 87 octane
Since my last knock sensor test I've replaced the entire exhaust system from manifold outlets to tailpipe end, the serpentine belt and the belt tensioner pulley. The graph below is from a brief datalog I performed in the garage with the transmission in Park and using 87 octane fuel with up to 10% of ethanol.
Bold green = engine rpm
Orange = knock sensor retard
Blue = ignition advance
Purple = A/F ratio
As the engine speed rapidly increased from 1,000 rpm the knock sensor retard dropped suddenly at 4,000 rpm from 0 degrees to -6 degrees and stayed there until the throttle was released at 5,400 rpm. As a result of the knock sensor retard the ignition advance dropped from 23 degrees to 18.5 degrees. It should be noted that the A/F ratio was 14.95 at 1,000 rpm when the throttle was mashed. It decreased to 13.75 at 3,000 rpm and then started rapidly increasing to a maximum of 15.97 at 3,200 rpm. That's too lean which corresponds with the knock sensor retard.
From the above I suspect that the richness increase is not able to keep up with the engine speed increase and there actually may be valid detonation detection. It will be interesting to see if I can duplicate the condition after I install a high flow fuel pump and a new fuel rail. I originally observed the knock sensor retard problem when performing uphill WOT runs. I will review those datalogs again but as I recall the A/F ratio was between 12:1 and 13:1 which should be rich enough to prevent detonation.
Purple = A/F ratio
