Knock sensor retard | Ford Explorer Forums - Serious Explorations
Knock sensor retard
2000StreetRod
Moderator Emeritus
Greenville, SC
00 Sport FI, 03 Ltd V8
While performing my WOT runs for my custom tune by James Henson it was discovered that my knock sensor was frequently retarding the spark advance up to 8 degrees. I assumed that the knock sensor was detecting my timing chain rattle as detonation and the PCM was performing as designed to prevent engine damage. Since I had a wideband air/fuel ratio gauge to monitor during WOT testing, I was able to determine if the fuel mixture was actually dangerously lean. Since it never was, James provided me with a tune that greatly minimized the knock sensor intervention. Upon completion of the custom tune James provided me two versions (with and without knock sensor intervention).
Just prior to beginning my timing chain repair saga I programmed the PCM with the knock sensor intervention enabled custom tune. I made sure that the engine started and idled normally (with chain rattle) and then pulled and repaired the engine. This morning I performed my first brief WOT run after eliminating my timing chain rattle. I had a fresh tank of 87 octane gas with up to 10% of ethanol. Upon reviewing the data log I was disappointed to observe as much as 8 degrees of knock sensor retard.
My next fuel tank fillup will be with premium fuel. Then I'll perform another data log. If there is no significant change in the knock sensor intervention and my A/F ratio is not lean then I'll assume there is no detonation problem. There may be another noise source that the sensor is detecting as knock or the sensor could be defective. I won't have any dyno testing done until I get the ignition advance right.
Premium fuel results
Since I've now burned two tanks of premium fuel, this morning I performed another knock sensor retard test. The results were virtually identical to those for burning 87 octane fuel. At full throttle going uphill in 2nd gear the knock sensor retard changed from 0.0 degrees to -8.0 degrees at 3100 rpm even though the air/fuel ratio was 11.4:1. I'm now convinced that there is no detonation and the knock sensor is either defective or responding to some other engine sound. The engine is very quiet after repairing my timing chain components so I think the next step is to replace the knock sensor. Has anyone purchased the AIRTEX / WELLS Part # 5S2221 available from Rock Auto?
