Early bronco coil buckets for dana 44 swap
expobronc
Hayward, MN
98 V8
How did you guys get away with using EB buckets on the Ex frame?? My frame has a large bulge where I would want to put the bucket...
Randall
Demon4x4 Member
Mo. City, TX
1991 Demon Edition
Callsign
KF5ZXT
I angled mine out a little bit and welded plateto the sides. The coil sat in better doing that anyway. pics at demon4x4.com/tech/dana44.htm The pics aren't to great, I am going to take new ones and change them out soon.
Sandy
Boston Area
2003 Ranger Edge
I notched mine and mounted them in the same location as the stock "X"; then welded them for support.
:usa: :chug: :ca:
Sandy
Boston Area
2003 Ranger Edge
expobronc,
How the coil buckets going ?
:usa: :chug: :ca:
expobronc
Hayward, MN
98 V8
I wussed out and just bought a new stock piece from Ford. I needed to get him back on the road. Hopefully if I save my pennies I can start reassemblying the dana 44 and the 9" and get this project wrapped up before this winter
EXPLORINAZ
Waterbury CT
91 explorer xl
hey whats up im looking for the specs for a dana 44 for the front of my explorer its a 91 any and all specs and info would be greatly appreciated. thank you....
Adam Foote
Katy, Texas
92 XLT
wow Randall, it looks like you had your explorer in the garage! how did that happen!!!!!!!! jp man..... :)
J Early bronco Gen II Ex, hybrid Offroad Projects 0
Dannyboy How To: Early Bronco Style Solid Axle Swap Offroad Projects 52
R XPLODER with d44 swap out of early bronco ? Offroad Projects 2
Stang5lgt Bronco II SAS Dana 30/8.8.... Offroad Projects 7
SVO42 SVO42's Bronco II fuel tank swap Offroad Projects 7
crazyflights B2 Guys Bronco Build, restore for crawling. Offroad Projects 131
crazyflights Budget build Bronco II, cheap & capable Offroad Projects 55
Diff Whack Daddy 88 Bronco II + 93 Explorer = Short and powerfull Offroad Projects 97
crazyflights 90 Bronco 2, getting 98 Ranger Cab and SOHC 4.0 Offroad Projects 39
Kirby N. Kirby's Spare Time Sucker.... 1995 Full Size Bronco Solid Axle Swap Offroad Projects 25
RFR2212 Bronco was tubed and painted! Offroad Projects 10
A Dana 30 and a Ford 9" off a 68 Bronco Offroad Projects 11
410Fortune THE NEXT STEP - 88 Bronco II Offroad Projects 15
B From Bronco to ROCK CRAWLER???? Offroad Projects 40
410Fortune 1988 Bronco II meets Explorer Offroad Projects 11
A What should I use, '77 or '78 Bronco? Offroad Projects 6
A D44 conversion with a '66-'77 Bronco? Offroad Projects 9
T '01 Explorer ST, Coil Sprung 4-link d44 front, d44 SOA Rear Offroad Projects 16
E Coil Spring or Leaf Spring for SAS? Offroad Projects 18
D Damarble's 01 Sport, coil sprung HP D30 SAS, SOA, 33s, 4.56s, lockers Offroad Projects 240
B HP Dana 44 with coil-overs Offroad Projects 2
zhanx Rear Coil Spring Swap Offroad Projects 68
C sport trac,coil overs and 38s??? Offroad Projects 2
Josh More flexible coil spring options for SL 5.5 Offroad Projects 14
Stic-o Stic-o's 2nd gen. radius arm/coil SAS Offroad Projects 710
T 2nd Gen Coil Sprung SAS Idea Thread Offroad Projects 77
F Coil mounts on EB D44 Offroad Projects 14
Rick Pumpkin Coil Over Conversion Ramp Photos! Offroad Projects 76
Similar threads
