85Dave
- July 4, 2001
- Germantown, TN
- 92 XLT
My temperature gauge has been swinging for many years now. I did a search here and found others having the same problem, but no solution. Well, I think I have the solution.
I suspected the problem was that when the thermostat was closed, there was no coolant flow through the engine and the engine would heat up the stagnant coolant. In the meantime, the coolant in the radiator is getting cooled way down. The coolant eventually gets too hot in the engine and the thermostat opens up, but now too much flow is going through the engine and the cold coolant overcools the engine. So the thermostat shuts, and the process starts over. The thermostat must be in an area that is cooled somewhat, as it doesn't seem to properly sense the bulk coolant temperature.
I took my thermostat out, and drilled a 1/8" hole in the face. This allows a little bit of flow through the thermostat at all times. As the engine heats up, enough coolant is flowing past the thermostat that it will start to open before the engine gets too hot.
After I did this, I took a 400 mile trip. The gauge was steady on level ground. Going uphill, it would move a little. Going down the other side of the hill, the gauge would move back. Overall it would swing less than the width of a letter. Before, it would move 3-4 letters.
