ThunderbirdSport
- August 4, 2013
- Location
- Thunderbird Heights
- Missouri
- 2006 Eddie Bauer V8
This may have been discussed in other threads, but I couldn't find anything directly related to what I'm seeking..
My high beam indicator is extremely bright. ASFAIK, it's the regular filament bulb, but I'd have to get to the cluster to find out for sure.
I want to dim it down a bit, it's really bright LOL.
The other question I have...LED foglights? Are they worth it?
As for fogs, is there a method to have them remain on with high beams? I'd like the switch to stay stock however.
Also, the rear heat/AC controls....is it possible to backlight them with LED? If so, anyone have the part numbers? The fan knob backlighting is out, and the temp knob's lighting is really dim, would like to have those a bit brighter if possible.
And last, has anyone ever came across a replacement LED for the headlight switch?
Mine's burnt out, and I found a thread with a link to a store, but I'm not sure what LED/base to order..
Many, many thanks for any words o' wisdom
