Someone please help me drive this to ground | Ford Explorer Forums
Masterd
Upland, CA
1993 Explorer Sport
Ive been searching for my ticking/vibration for a while now, and Ive just go done scoping the motor. Everything seemed OK untilI scoped a plug wire on the passenger side bank. I hear a clinking / knocking noise. I moved in closer and scoped the plug boot and the same noise is present. This did not occur on any other cylinders. I then had someone rev me up first to 1500 then 2000, and the noise gets faster, and theres a slight miss at those RPMs. Im still hoping that this is a rocker/lifter/pushrod problem.
Any suggestions are helpful to me
Thanks!
Btw...Im hoping this isn't rod knock or wrist pin wear. Ive been driving it like this for a while. The oil level is good and the only known leak is the rear main.
are the plugs and wires new? or have you checked for broken or cracked wires? i would say spark knock.... since it "misses" at higher rpms i would sugguest the plug wires, plugs, and coil pack in that order. hope this points ya in the right direction..
~troy~
Possibly a cracked spark plug or an exhaust leak?
Looks like the ticking noise was a loose plug. Middle cylinder on the passenger side bank. I could wiggle it with my hand.
thanks
