Anyone know of any spare tire mounts that will put the tire on the lift gate like the Bronco?
If you can get a bumper mount only or hitch mount it would be ok, other wise you may run into problems, surealNJ did the same type of setup with his truck "munk" and the body started damaging from the weight.
Another option but isn't particularly the cheapest is there is an aftermarket tire swing available and it uses the hitch for this purpose but some still allow towing use while having the swing in use.
