cfd911
- April 13, 2006
- chicago IL
- 2017 xlt 4wd
:fire: HI GROUP,
just wanted to add for you do it yourselfers, if your going to change spark plugs yourself as i did on my 2001 4.0l 70, 000 mi
do yourself a favor!!!! get plugs AND wires it will be much easier in the long run, i used motorcraft parts just to be sure $115.00
be patient and take your time, drivers side not bad , passenger side A BEAR TO DO some useful ideas that helped me ...
1. do 1 wire and plug at a time, AND don't insert the wires into the holders until all the wires and plugs are done...
2. spray your plug socket with alittle silicone spray inside.
3. only do it with the engine cold , my 2001 had aluminum heads you could damage heads if too hot when replacing.
4 you can put a drop of oil on the new plug threads or anti seize to help in installation.
5. un bolting the trans tube may help on passenger side.
6. remove the r frt tire ( it definatly helped me) getting that last plug done ,
AND TAKE YOUR TIME DON T RUSH and use hand tools to install the plugs!!!!!
good luck i hope this is helpful.......
