Steeda90GT
- July 6, 2006
- Central NJ
- 99 Sport
I might want to add that Borg Warner made plenty of OEM parts for Ford, including their T5 manual transmission.
DO NOT USE ANTI-SEIZE. That's the quickest way to rip the threads out of the head.
The system is designed with a specific torque spec selected to get the optimum clamping force on the joint as wella s resist loosening due to vibration. Anti-seize lubricates the threads, reducing the torque needed for any given clamping force. Reduced clamping force yields a reduction in the resistance to loosening.
Completely unnecessary, and not recommended by Ford. In fact, the service manual specifically states NOT to use any lubricants on the threads.
I did mine at 100,000 miles for the first time. I did them stone-cold. I had zero issues with the plugs being stuck in the heads.
Hello, Can you please direct me to the section in my 1997 explorer manual that makes this statement. Thanks, Joe
I agree you should not use a lubricant such as oil or WD40 on plug threads. When heated, the lubricant will bake and cause a bond between the plug and head which will create problems. However, anti-seize does not fall into that category. You can remove a plug or a bolt 50k miles later and the anit-seize is still in its original state and not hardened.
