speedo light went out | Ford Explorer Forums
gluvsave35
Long Island NY
1997 xlt v8
i have a 97 ex and one of the bulbs on the speedo went out
from 0-50 is semi dark
now i just wanted to know how hard it was to change that bulb like if its a big project or a little fix and if any body off hand knew the bulb that would be great
thanks guys
just pull the cluster out and it should be a size 194 bulb.
-Drew
This should help you remove the cluster so you can replace it. I would replace all the bulbs if I were you and also if you were thinking about giving your guages a new look I would also do that too.
Dead Link Removed
