The 04+ sohc engines have a different intake Plenum they changed the design and it is better imo
You can access the thermostat housing and the drivers timing tensioner without removing it
The old intake had two parts and a “power valve” they did away with all that and simplified things
Whenever I swap in an engine from a different year I use only the block and heads. I would use all intakes plumbing wiring sensors injectors and accessories from your original engine
Park both engines next to each other and compare each part
