glfredrick
- January 25, 2003
- Louisville, Kentucky
- 86-98 Ranger STX
Back when I was still modifying my 92 'Sploder, I had a concept idea for a spring over that would have solved a couple of problems at one time.
Basically, I was going to do a standard spring over for the axle; weld on the perches, and bolt it up, but with a twist on the front mount.
Instead of running the factory rock-catcher mount, I was going to pocket that mount up into the frame rail.
That would have the advanatage of a smooth rail (if I got hung up, it was virtually always on that mount!) and also reduce the amount of lift to about 3", which would make the front end work much easier than 5-6", with all the steering issues, etc.
I no longer have the 'Sploder, and am working on a full-custom Ranger build, but I thought that I'd toss out the idea for others contemplating the spring-over modification, but not wanting all that extra lift.
What do you guys think?
