rynil2000
- December 13, 2012
- Manchester, NH
- 2001 Explorer Sport Trac
Hey guys, I've been to the site a few times before, but this is my first time posting.
I'm driving a 2001 Explorer Sport Trac 4.0 V6, and it has been acting strange lately. When ever you shift into park the truck sputters 3-5 times and sounds like it's going to shut off, but then returns to a steady idle. So far it hasn't cut off, but it sounds really rough.
This only happens when you shift from drive to park. I can do it multiple times while sitting still and it will sputter every time, but recover as before. I tried going from neutral to park and the sputter didn't happen.
Otherwise, the truck runs fine; starts and drives well. I recently replaced the DPFE sensor to clear a "check engine" code. I'm not sure if that would have something to do with this problem. The check engine light has remained off since replacing the sensor.
I have seen a few posts about cleaning/replacing the IAC valve because of similar problems, but I just want to make sure before I go buying parts. I'm not sure if I have the job 1 or job 2 engine model. Is the IAC valve a relatively easy fix?
Any help is appreciated.
<== BTW, I love that this forum has this. I grew up in this van.
