Eric90XJ
- January 28, 2011
- Austin, TX
- 1998 XLT
This has been going on for a while but I'm finally getting fed up with it. Some time ago I replaced my upper control arms because the ball joint portion was worn out. I replaced with some parts out of the junk yard. Afterward I had terrible squeaking out of the front end. I have tried re greasing which worked temporarily but ultimately did not solve the problem. I am not sure if I just got a bad set of control arms. One thing to note is that the bushings have a metal washer on either side. I am certain that this metal on metal contact is causing the noise. Is there perhaps a set that has just a straight poly bushing?
