I have 94 X that stalls whenever I press and let off the accelerator quickly. Kind of what you would do when backing out of a parking spot or when you think you may cross an intersection but change your mind at the last minute. It will stall everytime with the A/C running. With the A/C not running, the engine studders a little but it doesn't stall. I have cleaned my IAC valve but that hasn't made any difference. I'm not getting a CEL light. My fuel pump does have a fairly loud whine to it, but I'm not sure if it's an abnormal noise, plus I thought when the fuel pump starts to go bad it's either all or nothing. I have also changed the fuel filter. Any ideas of things to check would be appreciated.
Nathan
Nathan
