explorerphil
- May 19, 2014
- 2005 ford explorer
Hi everyone,
First things first, I am the proud owner of a 2005 4.0L Explorer XLT. I am not a mechanic but I do do most of my own vehicle maintenance and service, the biggest reason is that I like knowing the job was done with care and attention (I may have trust issues). On to the topic of this thread:
A few weeks ago the engine stalled on me at a red light but then started back up right away without issue. While I was driving there was no stalling, performance was good/normal. I continued to drive the truck daily and the problem continued to manifest itself a couple minutes after the engine would get to up to running temp. One day my wife was driving to pick me up from work and she said it stalled every time it was stationary. I went to meet her at the truck and it was in limp home mode I think, It would start and then die as soon as I put it into gear. I ended up towing it home. The next morning it started fine but continued to stall at temperature (the last two sentences may just be a red hearing). Only when it went into limp home mode did I get any codes. The codes were P2106, P0303, P2006, P0621, and P0600. I cleared all these codes and they did not return.
After doing some reading on this site I though my symptoms best resembled a vac leak but could not find one. Then I thought a faulty fuel rail pressure sensor even though it didn’t give a code for it so I pulled the manifold and changed it. This did not help, the problem persisted. Next on my list was a good throttle body cleaning and fuel filter, did that but no change. Frustrated, I changed the MAF/IAT sensor with a remanufactured one from napa and still no change. Just the other day I seafoamed the truck (skipped adding any to the crank case) and the problem didn’t manifest itself for almost a whole day, I though that might have done it but the problem came back that night.
It still feels like a vacuum leak but I’m not having any success finding it.
Before I go for big ticket Items like throttle body, fuel pump, or coils/wires/plugs does anyone have any suggestions?
EGR Valve?
EGR Valve?
