TomCat_Ford
- January 24, 2009
- 98 Explorer
Well this is my first post here on these forums. Yesterday afternoon I bought a 1998 Ford Explorer Sport with the 4.0L SOHC engine and an automatic transmission from a private party in my state. The reason they were selling the vehicle is because of this very problem- they couldn't afford to figure out what the problem was and have it fixed.
The problem explained... when the engine is cold, it works perfectly fine. The idle is perfect, it sounds good, it accelerates as it should, etc. Once the engine warms up, however, it can stall when approaching a stop sign, light, etc. After the engine has stalled, you can put it in park, turn the ignition key off, turn it back on, and the engine will fire right up (immediately with zero hesitation). At this point it is idling as it should and acting just fine. But when you go to put it in drive, it shuts down. I even tried double footing it so I could rev the engine up a little bit to see if that would help, but it simply shuts down... just as if I had turned the key off at the very moment I get the shifter lever in drive. Now here's the weird part; if I put in reverse, 1, or 2, it works just fine. There are no problems whatsoever in any of those gears. The only time it will stall is if the vehicle is in drive. From a stop, I was unable to get the vehicle to move in D after the engine was warm. To get it on the trailer, I simply put it in one of the other gears and drove inside the trailer after I bought it.
Any thoughts as to what might be causing this issue?
Thanks for any and all help.
-TomCat
-TomCat
