starter engages for a second and quits. | Page 2 | Ford Explorer Forums
Found it. Tests less than 9v
On both sides? One side comes right from the battery and should have +12v.
OK got ya.
positive side shows same as battery +12v
other side shows less than 9v+-
You should have 12v all the way to the alt. Sounds like you may have some corrosion issues.
There is also a 30 amp mini fuse in the dist box(#14 I think) that supplies 12v to the regulator. Check that as well. Only having 9v at that mega fuse is not good. I don't think the alt will charge with less than 10v at the rectifier. There's got to be a bad connection or some corrosion either at a connection or in a cable.
