Karmana
- May 2, 2006
- Addy, WA
- 1992 Explorer EB
Hello all, first time here, first post. I have a 92 Explorer EB, that has a handful of 'issues', but they can usually be lived with (low budget).
This started a few days ago. Twice in one night, there was a squeel/grind noise, when attempting to start the engine. After several bumps of the key, it started. The following morning (and since then), grind/squeel constant, no start. It sounded exactly like a broken pinion gear, spinning, but not engaging. So, pulled the starter, took it to Schucks. Starter tested out ok on the bench, but purchased new one anyway.
Replaced starter, and replaced the serpentine belt at the same time (it was severely cracked). Now, the truck starts every time, but there is still the grind/squeel sound, EVERY time the key is turned. I have massive corrosion with the battery cable terimals (always have, wire brush them when it gets bad- wich I have also done this time).
The solenoid on the firewall was replaced 4 months ago. So what in the heck is causing the squeel/grind?? Incidentally, my '88 Chevy PU does the same exact thing, but only when the battery is too low to start the truck. I'm confused....
Thanks in advance!
Thanks in advance!
