Wanted - Starter relay wiring photo. | Ford Explorer Forums
Wanted Starter relay wiring photo.
Parts or services wanted
donhart
Palmer, Alaska
1992 Explorer
Starter relay wiring photo needed urgently for a 1992 Ford Explorer. Would not start. Found one terminal had broken on the molded plug that fits across both posts of the relay. Removed the wiring, split the molded plug, cleaned the one wire of insulation at the end. Replaced wiring. Apparently wired wrong. Engine started and starter continued to engage. Cut positive battery cable. Removed the wires from the relay. Need photo of wiring for the relay urgently, to get it right before I try again. Thanks, DonHart
...You should find what you need at the bottom of the first post of this thread..;)
http://www.explorerforum.com/forums/showthread.php?t=284981
...The left side wire is coming from the battery while the right side wire is going to the starter...
Starter Relay wiring photo
Thanks very much for the starter relay wiring photo. I followed the wiring photo, but the key does not provide any ignition when turned on, No lights, no warning sounds and no movement in any gages. I now need help in finding the problem with the ignition. I have a volt-ohm-amp meter but need to find out what to test to find the problem. The left post on the relay has the same volts reading as the positive post of the battery. I need to figure what to test and in what sequence to find the problem. Thanks, Don Hart
