1997XLTRollover
- February 28, 2007
- 1996 AWD 5.0
Ok guys as some of you saw my starter solenoid failed recently in my 96. To make a long story short when I pull the "S" terminal wire off my solenoid and test voltage to it with the key out of the ignition, I'm seeing 3 volts. Is this normal or could this have been the reason my solenoid died after only a year of replacing it?
I know it's supposed to get 12 volts when key is in "start" and "zero" when key is off, but is 3 volts considered "zero"? Can someone with a V8 truck measure this and see if they see the same 3 volts?
EDIT: I should clarify, I'm seeing the 3 volts on the wiring of the "S" terminal, not the terminal itself.
