Nick26
- June 30, 2003
- Cumberland, RI
- 98' 5.0 XLT
Im changing the clutch in my truck and ofcourse i had to remove the starter but i made the stupid mistake of not disconnecting the battery when I removed the starter so i think that is what caused the start of my problems... and sorry for the long write up but i just wanted to give all the details of the story...
After I got the clutch all changed and the tranny back on, I bolt the starter back on and try to start it. It started right up but i heard this loud clattering noise too, so after it ran for like 10 seconds I shut the car off, but the starter was still spinning (even though the key was out of the ignition!) put the key back in and just turned it to the on position and it started again without having to turn the key to the start position. pulled the key out and again and the starter was still going so i disonnected the battery and it stopped... trying to figure out what was wrong i reconnected the battery (starter didn't continue to run) tried to start it and it immediately blew the 50 amp ignition fuse. So i got back underneath unbolted the starter again to check the terminals to make sure nothing was shorting out, everything looked good so i put it all back together, replaced the fuse and tried again. it blew that fuse too. so i just took the starter off and took it to advance auto for them to test it and they said it did't look like it was retracting like it should. So i got another one from them and put it in (side note, when i was putting it in i heard a random booong noise just as the bolts were almost tight). As soon as I reconnected the battery i heard this clicking noise which sounded like it was coming from the starter and i got under there and put my hand on it trying to tell but wasn't positive. so i disconnected the battery again reconnected it, and then no noise but the interior lights wouldn't come on either and trying to start it did nothing. I checked alll my fuses and and tested the starter relay and they all seemed fine. Now i was playing with some other stuff like rewiring my fog lights and in the course of turning them on and off i think I probably killed the battery. the multimeter read like 10.8 volts so i was going to try and jump it with the battery out of my mustang tonight but is seems like that may not be the end of my problems. the solenoid is attached the starter right? so when i replaced the starter it should have had a new solenoid on it too? think i got a bad starter, i have a lifetime warranty so i can get another if thats the case? any ideas at all please let me know, thanks!
