starting problem | Ford Explorer Forums
starting problem
crazyfoolreal
Baltimore
'93 XLT 4x4
my exploder has been sitting in front of my house now for a week because it wont start. I tried resetting the fuel pump and that did nothing unless i was doing it wrong. Today it just started right up like there was nothing wrong with it. The battery and starter are both fine what could the problem be?
Could be a number of things.. Did you check the fuel pump relays? Also check the coil wire and make sure you get spark plus check the fuel pressure on the rail.
exactly how do u find the fuel pressure?
You need a tool like this one to measure fuel pressure.
