mike walsh
- May 7, 2001
- Red Bank, New Jersey
- 95 EB
Hi,
I posted a problem here a few months ago that could not be solved even by Ford. I have an auto starter that was professionally installed and never had a problem. Suddenly, I would need to turn the ignition or the electrobnic start 10 times or more before starting. All I would get would be a "click." A friend got under the car, hit the starter while I turned the key and it started. So the starter was replaced in July and all was well. Then I moved from NJ to NC and it started again.
Another aspect occurred where if I held the key in start position and moved the shifter back and forth I's eventually get it to start.
Now that the humidity has dropped and the temps are pretty much under 75 degrees, the car starts 99.9% of the time.
I had someone tell me about an oxygen sensor on the starter of their import car that caused the same problem. But the Chilton's book shows no such animal.
When I brought it to Ford it of course started and the neutral safety switch was not defective.
Any thoughts appreciated.
Thanks,
Mike in NC
Thanks,
Mike in NC
