symon_say
- August 12, 2007
- Dominican Republic
- 05 F150
I'm making my eX as secure as i can to left nothing to does mother ####er that steal the things that take us a lot of work to get. I'm changing everything of place to make almost impossible to reach unless you know the step to get it.
I had my amps under my seats, they cant be seen from outside, but once inside it was really easy to just steal then, so i decided to move to some place safer, and this is the work i did.
I put then under the back compartment of the trunk:
Also i install some piezo horns to make my alarm louder, i'll install 4 more inside and another 6 tone horn outside, with horn hock installed to.
I hide the wires that you cant see any of then:
Install to computer fans in push/pull config to move the air inside, i'll upgrade for some thermaltake later.
The mounting of the amps:
The tools and lot more outside
The final product:
Now you can see then:
When i build the box for the Type R, the stealth will be complete, the box will be make to fit exactly under the trunk cover, the box will be tight to seats be some steel cables and look, that way the only way to move the box is to have the keys of the looks, so if you cant move the box you cant get to the amps.
The sub itself will be secure by t-Nuts and security screws, that way it will not take my sub either in case they break in.
The alarm will be move from the place it is a hidden somewhere in the eX with a back up battery, that way no matter that the disconnect the main battery, and with all my horns make noise, they most have to leave my truck alone.
Hope this help someone.
The final product:
