I have stock 15" rims. What is the largest tire size that will fit at stock height? I am planning on the torsion twist, but would rather be sure stock height would fit first, then after the lift I will have better clearance.
31X10.50 R15 will fit on the stock rim perfectly and they will not rub even if you don't have a lift. On some vehicles the rear tires will rub slightly at full articulation but I have not had any problems while off roading.
