- December 22, 2021
- Los Angeles, CA
- 1998 XLT 4x4
24 Rngr 4x4
1. alright!Oil pan bolt still leaks yes, hasn't gotten worse though. It may be slightly better (tough to see unless i measure exactly how many drops it drops each time after it comes back from a drive. still trying to determine if the Liquid Moly Oiler saver has improved it.
I've been checking the rad neck every 3 days in the past week and no big drop from the rad. But some days the coolant will show about maybe 3 or 4 inches below from the top of the neck, while others will have the coolant so full it actually spits a bit out when I release the rad cap. Is this normal?
2. thats a good sign so far, doesnt seem to be losin much then! are you releasing the rad cap when hot? or cold? if its hot sometimes it can spray and thats a big nono release when cold!
