Straight answer, what are the best lights.. | Ford Explorer Forums
ImThWlfMan
Oklahoma City
2000 XLT
I want to get some real bright lights for my 2000 Ex Limited. I LOVE the fog lights. But i think they could be a little brighter. I mean, i dont want them to be spot lights, ok, so i do, but not really. I was driving out in the middle of bum fu** egypt last night. And i wanted to be able to see. I had my fog lights and my low beams on and it was pretty good. But i wouldnt mind it being a little bit brighter.
I have some blue lights in my Monte Carlo. They are ok, but i think i am going to take them back. It was more than 60 clams for high's and lows.
Thanks for any suggestions.
Jeff
From my personal experience (same headlight housing as you) I have used the stock bulbs and the Sylvania Silverstars. The Silverstars emit a whiter, cleaner light than stock. However, when on the road the more yellow colored stock lights appear to actually light the road better than the Silverstars. I have just recently found this out. And all this time I beleived the silverstars to be better because they looked better :rolleyes:
Another option you have is to upgrade your current wiring and install higher wattage bulbs. This is probably your best bet for the most cost-effective light performance.
The last option is to go with a HID conversion kit. These kits run $300-700 and emit a mich brighter, whiter light than stock. I'm still skeptical though because most are not DOT approved and I don't think the increase would be as dramatic as expensive import cars. Not to mention the type of lense we have is not designed to accomodate HID's.
Good luck with it.
