Lazzman
- June 27, 2005
- Massachusetts
- 1998 Sport 4wd- V6 Sohc
Hmmm, I have been experiencing this somewhat strange problem ever since I installed my Cold Air Intake about a year ago.
Off idle and under mild Acceleration the engine runs really great, however if you dip into the gas at casual cruising speed, say around 35 or 45 mph
the Tachometer will jump to 3000rpm and hold there. If you continue to push the accelerator down further the engine appears to hesitate or bog and the tachometer will only climb a couple hundred more rpm's to 3400. You can hear the airbox trying to suck air as the acceleration seems to bog out.
If you keep your foot in it, it will last about 2 seconds before the engine is able to overcome what ever is going on and start to rev up the RPM range normaly again.
If you put the pedal to the floor at any time during this situation, the transmission will kick down and put the engine into WOT, where there is no bog issue.
Sometimes it is worse than other like during damp days, sometimes the engine will just rev up through the RPM range normaly without hanging up at the 3000rpm range.
At first I thought this was a sensor but I have replaced most all of them with little results, scanners have not been able to pick up anything either, iginition and fuel components have either been replaced or checked. I am thinking that it may be the transmission, as I have noticed the tach slipping lately.
I have heard others complain of this problem but have not heard what the overall outcome was.
Does anybody have any idea what could cause the engine to hang up in the 3000 rpm range under heavy throttle, in open loop (running off the sensors feedback - not WOT) ? Trying to apply more gas just bogs the motor more, until it can finaly overcome what ever is happening and continue to rev.
It was once described to me by a mechanic as hanging up or stuttering around the 3000rpm range. Though he could not figure out the problem.
The idle is also low to as if the a/f mixture is way to rich. Very responsive off idle to about 1/3 pedal, once you goose the gas it will jump to that 3000rpm sticking point and hold.
If anyone has experienced a similar situation or has any suggestions I would love to hear from you.
Suggestions and positive advice only please, the extra flogging and sarcasm is not needed. Especially after investing $$$$ over the last year.
The $60,000 question is: What would cause the engine to hang up at this rpm point and eventual overcome up after a few seconds???
