bob93explorer
- July 11, 2014
- 1993 Ford Explorer
We are in MT now.
It is a limited, 4.0, 4wd, AT. Thanks for the fuse info - they are not identified in my manual or haynes...........
I can't reach the antitheft mod until I get a button tool today. Jane doesn't want me to scratch up the plastic panel
I will do as you say this afternoon.
Does anyone know of a "disable alarm" brown wire from the computer module? That was supposedly mentioned to someone by a 30yr master Frod mechanic...? Said all you have to do is ground it and it disables the system. I will be pulling harnesses on the rear modules today. I pulled the 3 harnesses on the RKE mod yesterday. The big one killed the power to the unlock button, the others seemd to have no effect. Is there an internal board that can crash due to constant banging around?
