ponkotsu
- October 29, 2012
- Colorado Springs, CO
- 2005 Lincoln Aviator
I got my rough idle drivability issues about 99% fixed. But still had an occasional rough idle. What I've determined is that it is only happening at 900-1000 RPM. Condition doesn't matter. In P, N, driving, cold, hot, etc. Happens when idling steady at 1000rpm. It happens when revving up past 1000 or down. Seems like it always runs rough at that point. Other than that, it seems to run perfectly. It idles at 600rpm as smooth as can be. Get's great mileage. All the scan data looks normal, and I've never had a code.
I'm going to do some testing to try and figure this out. If anyone has any suggestions I'd appreciate it. I'm going to start with a cylinder drop test while trying to maintain 1000rpm.
I'm not 100% sure it's a misfire, or if it's some vibration in the engine. Maybe harmonic balancer or fan? Chain?
