94stockexpl
- September 3, 2008
- Hesston, Kansas
- 94 XLT
All:
I don't know what's causing this noise and am hoping someone can help out.
It started 3 days ago out of the blue. Sounds like something rubbing every time the wheel goes around. As I speed up it speeds up; as I slow down it does also. When I come to a complete stop, ther last couple of revolutions of the left front wheel sound like something is "creaking" for lack of a better word.
I have replaced wheel bearings and races, as a mechanic I know suggested them after riding with me and hearing the noise. I did not have access to a socket for the bearing nut so I used a BF channellock pliers and gave it all I could, pausing to turn the rotor as I tightened it down. Then I backed it off and finger-tightened it, replaced the lock key and finished it up. Took it out and after about 3 miles of driving around town the noise returned. I went home, pulled the thing apart only to find that the rotor was wobbling on the bearings/spindle like I had not even tightened it. SO I tightened it again, this time leaving the nut a bit tighter when relacing the lock key.
I'm leaving town with it for about a 50 mile round trip this evening. Will be back around 11:00 PM and will check to see if anyone has any ideas and also to report what happens
My biggest querstion is this: What else is there in that wheel/hub/spindle area that could make a noise as the thing rotates? 4WD can not engage as I've gutted the auto hubs and pulled the cam off the spindle temporarily. )It needs the auto hub washer fix yet and I just found the washers.
Whatever anyone can suggest I'll listenh to and try
Thanks
John
Thanks
John
